Distorted video
  • 6 Replies
  • 3855 Views
Mikeday1uk
Hi I keep getting completely distorted videos being captured - sometimes it works fine then I’ll get 3 or 4 in a row that are either blank grey or covered in lines (see image) - any ideas?
6 REPLIES 6
ShayneS
Hi @Mikeday1uk
  May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Mikeday1uk
Hi - I’ve changed the batteries and rebooted both the hub and my router. Beyond that I’m out of ideas.
If it was happening all the time I’d think it was a weak Wi-Fi signal but it is only happening sporadically
ShayneS
Have you tried to remove the cameras from Settings > My Devices > Re-add them?
Mikeday1uk
Just tried that now will see if it improves thanks!
Mikeday1uk
So apparently that didn’t work, getting the issue on both cameras at the moment - see photo
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
