I work on a college campus and one of the professors bought these cmaeras to monitor a lab. After plugging in the home base I have tried to discover it in the app and through a laptop that was wired through the same switch with no luck. I was wondering if anyone else has set these up on a larger scale network and if they have any advoce for settings I can check.
Thanks in advance!
The app or browser are the only access methods. To go from there you need to log into the servers to set up an account and register the base. I haven't run into this but I'm guessing that something is being blocked, either the Netgear servers and/or port 443 (HTTPS). Are you able to click on the setup of a new system button and it just fails to find the base or what? I still suspect it's an IT issue. A possibility to work around this would be to take the base home or any other place that is a typical home-type network and try setting it up there.
IT may have DHCP server settings that are preventing the base from getting an IP address. Are all 3 LEDs green on the base or is the Internet one amber? There may also be blocks to the Netgear servers set on the firewalls. Other folks have had similar issues on a company LAN.
You'd need to work with the university IT staff to verify that the base is getting an address as well as ports 80 and 443 being open to the Arlo servers (netgear.com). If they are blocking something, they're the ones that would have to unblock it.
We have all ports open and 2 of the LED lights are green. The internet light stays green even if we unplug the ethernet cable though.
You need all 3 green. What's off or amber?
There is just a power light and a ethernet light that are both green. The instructions say those are the only 2 that need to be one. We can see that it is getting an ip address but when we try to connect through the app or through the webpage it doesnt see the device. Is there any other way to try to connect to it besides the app or webpage?
I am in IT and I am working closely with the network admin and he has assured me all ports are open. We can select to set up the new device it just never finds the home base. Taking it home is a good idea but if we set it up at home would it connect when we brought it back on campus? Wouldn't this issue just continue once we reconnected it to the campus network?
I took it home and registered it on my home network. After bringing it back on campus I was able to see the cameras and connect on my phone and through the webpage.
You could try a factory reset to see if that helps.
We're having the same issue at my work (school with business network setup). I'll try what you suggest here. Thanks!
Phone or iPad is not discovering the device. I have 3 green lights.
How do you do the factory reset. Getting close to returning this
Dwheeler wrote:How do you do the factory reset. Getting close to returning this
With the new version of software.... Use a paperclip and depress the 'reset' button on back of base for 5-10 sec till the front leds start to flash.
Getting the same problem. Tried reboot, reset etc. Waiting on help line for over an hour. Time to go to Nest.
mof,
What issue are you having? Please post details so that we can offer assistance.
