I have searched for the answer for this and have not seen anything that specifically addresses it. Every time a clip is saved due to motion detection the library date/time is 2 days prior and 7 hours fast.
If I record manually it saves it perfectly with the correct date and time. Tried changing time zone, resyncing cameras, power cycling base station and nothing has fixed the problem.
Example:
Motion sensor tripped on 9/28 at 5:00 pm will show in the library as recorded on 9/26 at 2:00 am.
Manually recorded on 9/28 at 5:00 pm shows correctly in library as recorded on 9/28 at 5:00 pm.
Any help would be greatly appreciated!!
Example:
Same here... can't seem to find a resoultion.
2ifbysea, markminer
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
