Finally up here too. Hope this is an isolated issue and not a hack!
Like everyone else here, getting alerts but could not access cameras.
I was a former VueZone user, and when thar service was stopped, and all users offered to migrate to Arlo for a very low cost, I did it, and for at least the last 2 years its been solid.
However today's incident is similar to one about 3+ years ago. Could not login, could not retrieve images from the VueZone Server. At the end, everyone was sent an email stating that NetGear was upgrading the backend servers for better reliability but someone messed up the database server and took the system down for 3 days. (They had to rebuild the server from backups)
At least today was only several hours.....
But it does make one nervous that we rely on these cameras. Even a few hours of outage with very little to no correspondence is concerning. For me what is even more concerning is this happened 3+ years ago with the older VueZone System. Someone did not learn from their past mistakes. Again at least it was not 3 days like last time, but come on. At the very least someone should have learned a lesson about communications.
There was a precursor to this about a week ago. I lost connectivity to 4 of my 5 cameras. I was told to reset the affected cameras by opening and closing the battery door, and then resyncing them. Opening and closing the battery door on a few of the cameras not an easy task due to location and/or mounting. Resycning them brought them back on line, and at that time I asked was a backend or SW push upgrade responsible for this, and the tech could not answer.
A little more transperancy please NetGear/Arlo teams.
An email blast or posting about pending upgrades would be nice. Definitely one when an outage like today is occuring.
We have all come to rely on these cameras, so keeping us informed would be a great step forward to recovering from today's outage
Just my 2 cents
Dear Arlo Customers,
Thank you for your patience. Arlo services are now fully restored. We sincerely apologize for any inconvenience this has caused. The disruption in service which affected some of our customers was due to a technical issue that arose during routine system maintenance.
For updates and more info on what happened, please visit this thread in the Arlo Community.
@Lentilwrote:Netgear/Arlo techies & managers are textbook arrogant incompetents.
Finally, I'm back up.
This is a perfect example of why we need a local mode.
Not Fixed. Takes 5 or more min to get past the getting status screen. Then when you hit the live view button the wheel spins and you get no live feed. What kind of fix is this? SOmeone needs to loose their job over this one.
For more information and further updates, please check this discussion thread: https://community.netgear.com/t5/Arlo-Stories/Arlo-Service-Down-Temporarily-Unable-to-Login/m-p/1521...
Thank you,
- The Arlo Team
Please fix the log in issue. Still getting hung up on the getting info screen. Your fix is not a fix at all.
the service is down for the third time in a week. what's the problem?
What's the error message? It's working fine for me although I had to clear Arlo cookies in Chrome:
MrLucky777 are you back up? I haven't noticed any issues here in Louisiana.
Power off your base station for one minute and then power it back up and let it reset. Worked for me.
Brian
No telling what all the problems are with these massive failures. As a last resort, try doing a factory reset.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
Brian
Yes, but you will have to add the base station first from the Devices page. Then add the cameras one at a time.
Brian
Did you try the factory reset - ? Did it work?
Im having same issue with Arlo Pro 2 - it appears to be connected - LED all green and my router shows a VBM4000 device. But when in the app - I frequently (Most of the time) receive a Bass Unit Offline message. I think the issue is outside of my network as the problem is intermitent.
