Once you click on the first Notifications, another Notification section displays. While it doesn't look like it will do anything, actaully click on the second Notifications.
What phone, What OS?
I've seen an update of FW change setting back to default before....
Try changing the sound and save it, see if it changes, then try and go back to the original you used.
And/Or delete the app and reinstall and see if that helps
Ok, sorry , your not crazy.... just tested an S7 with the sounds and it's not the one picked but default sound like your getting.
FW is dated 1/18/19 so it is more than likely the FW change has screwed things up.
Use the phone settings for the app to set the sound. Apps, Arlo, Notifications, Notifications (again - just click on it), Advanced, Sound.
To be clear, and fair, I didn't find that. @JoeCymru did.
I changed the Notification Sound through the Arlo app on my Verizon Samsung 8 (G950U) but I still hear the notification sound set up through the phones settings. Android version 8.0.0. Any suggestions?
Set it up through the phone not the app. Settings>Apps>Arlo>Notifications>Notifications (not the toggle, just in the general box but make sure it is on of course)>Sound. Choose your sound. The sound change in the Arlo app is broken.
It took a little tweaking but it worked! THANKS!!!!! I didn't even know that feature was available. I'm not very tech savvy 😞
So in Android 8.0 - this 'path' doesn't exist. Settings->App info->Arlo->App notifications
Is what I get. Under App notifications all you can do is turn it ON. Allow notification dot. Then Categories->Always Listening and Categories->Notifications which are just toggles - no other options.
And to make matters worse the latest update now constantly nags me that "Geofencing is enabled". I know it is enabled - I'm the bloody person that turned that on.
I LOVE the system - but the app is still really horrible in some ways. One thing gets fixed and it breaks something else....
Samsung Galaxy Tab S3 tablet here on Android 8.0. I get:
Settings, Apps, Arlo, Notifications, Notifications (turn on), Importance, select High or Urgent, go back to previous page and set the desired sound.
I get the option with the latest version (Pixel 2)
if you go to the notification setting in the app it also now takes you to the correct location to set up notifications in Android
Hi everyone,
As JJS68, there is a new Arlo Android app update that released recently. Make sure to install the latest version, which is 2.7.2.
If your phone is running Android OS version 8.0 or 9.0, the Arlo app notification preferences are now managed in the Android system settings menu.
Thanks again for waiting patiently regarding this 🙂
