I've opened and escalated a ticket on this topic, I will provide an update as soon as I have more information.
@a_brittis wrote:
I'm using 8.0.0, which has this option to set the notification sound via the Android System Settings.
This appears to be a function of the phone as well as the OS> I have a Galaxy Tab S3 on 8.0 and a Pixel 3XL on 9 and neither has the option in the phone settings for the app to set/change the notification sound.
The base has nothing to do with the sound. That's strictly a function of the phone. The recent Android app update has caused a problem with the ability to actually use a custom sound instead of the default sound for the phone.
Still waiting for a fix (update) from Arlo..........
Thank you!!! GOing into the Actual phone settings and changing the notifcation actually worked! This was driving me crazy! Thank yoU!
I set the notification tone on my Android phone to NONE, but I still receive audio alerts! Short of turning off push notifications entirely, how can I fix this? I have already uninstalled and reinstalled the app several times, but it continues.
I have had these cameras for several months - the problem started with an update in the last week.
Is anyone else having this problem and how do you fix it?
Since the update I don't get any push notification alerts/sounds at all, and can't stay logged in. When looking at my camera in "Devices", the sound icon is greyed out, if that matters. I NEED the notifications!! I have reset, uninstalled, reinstalled, rebooted everything, and nothing helps. HELP!
I am having the same problem with notifications sounds resetting and not being able to change them. Even more peeved as this option is not available on iPhone so I had to go and purchase a Samsung (that I only use for louder notifications whilst sleeping) as it looks like they will never fix the iPhone problem only now to find out the the latest update has taken away this option for Android too. Come on Arlo lift your game. You charge premium prices for your cameras how about providing at least the service you advertise eg notifications that work!
Reinstalling app doesn't fix it.
Why dont push notifications sound changes take affect?
I changed the sound but yet default notification sound still come thru
App shows new chosen sound and is saved and changable and shows saved new sound but continues to sound default.
I have been a user over a year and was able to make this change in the past for some reason it no longer is working, even tried reinstalling app.
Google Pixel 2 XL - Android 9
I had the same problem. Thanks to the latest Android update where a lot of the custom sounds were taken away, the only way i have found to be able to change the sound is to go into your PHONES settings, under apps, select the Arlo app, then go down to notifications, and then on the bottom select notifications again, and there you can choose the level of "severity" of the notification AND should have a place where it shows what sound will play. I have a Samsung Galaxy S8+ so im sure it will be somewhat different but hope this helps at least get you in the right direction.
I'm running an original Pixel XL with Android 9. The smart notifications and person detection have started working. However it won't use the notification sound I choose, just the default, it only notifies me if the phone is active (ie: person gets detected at 10am and records, if my phone is laid down with the screen off it doesn't notify, if I pick it up @ 10:20am I'll then get the notification), and there doesn't seem to be anyway for me to make it overide DND anymore...
Also, still no idea of what how to use activity zones. I can create them, but not specify what to use them for.
H
Regarding custom sounds, go through the phone not the Arlo app. Settings>apps>Arlo>notifications>notifications>sounds. This works for me changing sounds, Arlo app does not after update.
Same for me.
After last week's update I was having problems with push notifications as well. Problems varied from no notifications or the custom sound not working. I've worked around this for my Android 8 Huawei P9 lite by uninstalling Arlo and downloading a previous version from APKmirror.com. Once on apkmirrior site, seartch for Arlo. I downloaded a version from October and I'm now getting immediate push notifications with my custom sound. Now I just need to work out how to prevent auto updates from Google Play so I don't have to keep doing this.
Thanks, @solidamber.
1  -
1  -
1  -
