Connection
I have three cameras. Two of them are working fine. The third one syncs successfully with the base and has a strong network connection and fully charged batteries, but when I try to view, I get the message that there is a problem establishing a connection to the camera. I have tried resetting the base. Firmware is 1.9.673_9183. Can't get an image.
It may more than likely be the base and/or cameras s/w version...not the version you gave.
TMK;
cams are now 1.2.2545 , bases are 1.4.2627
Location of info is SETTINGS/BASE STATION SETTINGS and CAMERAS ( bottom of right page )
Sorry I mistakenly gave the wrong version numbers. The cams are 1.2.2545 and the base is 1.4.2627. I had to return one of the three cameras because it wouldn't connect. Exchanged for another. Motion detection does not work on any of the cameras.
