Connecting Base Station to internet with new router
My old Arlo Staion is not connecting to the internet after I have installed a new Nighthawk router, Can anyone suggest a method, other than reset factory settings, as I have done that, Cheers
Did the Arlo have a fixed IP address? Has the network changed by introducing a new router, and therefore the Arlo cannot connect and/or isnt getting an IP address assigned to it?
Are you connecting wirelessly or wired? If wirelessly it is unlikely that your new router is using the same SSID name and password for its Wi-Fi, so you will need to update your Arlo device with this new information.
If wired, I would factory reset the Arlo device so that it will automatically obtain an IP address from your new router.
Hope this helps
Modem: Bipac 8800NL | Routers: R7800, R8500 & R9000
Powerline: PLP1200x4 PL1200x6 | WiFi Extenders: PLW1000 & XWN5001
Switches: GS105Ex2, GS105Ev2, GS108Ev2, GS305
