Infrared Light
  • 4904 Views
  • 2 Likes
t3h
Since the IR Light built into the camera is horrible  I want to buy a standalone IR illuminator.
What wave length of IR light does this camera support?
Hula_Rock
Prodigy Prodigy
Prodigy
@TomMac ?  he might know.
850nm. Lots of options on Amazon.
J is correct... it's 850nm.
I have used several..... But to be honest, the one I use the most and like is the Outdoor flood light that was designed for the older Vuezone.
You may be able to find one on ebay or similar , there are many out there.
It has a day/night sensor that auto turns it off in the day time.
