Since the IR Light built into the camera is horrible I want to buy a standalone IR illuminator.
What wave length of IR light does this camera support?
@TomMac ? he might know.
850nm. Lots of options on Amazon.
J is correct... it's 850nm.
I have used several..... But to be honest, the one I use the most and like is the Outdoor flood light that was designed for the older Vuezone.
You may be able to find one on ebay or similar , there are many out there.
It has a day/night sensor that auto turns it off in the day time.
