Color v B&W
Hi PeterP,
Let me inform you that as per our data center, it shows that the firmware of all your Arlo cameras are not on the latest version. I suggest that you update its firmware. Kindly check these links below as reference guide:
What do I need to know about Arlo camera firmware updates?
How can I trigger my Arlo system to update its firmware?
Furthermore, about your concern on your 2 cameras that displays black & white, is there sufficient lighting on where they are deployed?
Let me know if you have already updated the firmware of your Arlo cameras and if same problem occurs. I will be looking forward to your response.
Regards,
DaneA
Arlo Team
Kune wrote:
My arlo camera just is now streaming b&w, why is that?
the cameras sense the light level and automaticly switch over to B/W if light levels fall below a certain point
