  • 4 Replies
  • 5684 Views
  • 5 In Conversation
PeterP
Just set up and whilst one is beaut colour the other two are B&W ?. What have I done wrong.
DaneA
Hi PeterP,
Let me inform you that as per our data center, it shows that the firmware of all your Arlo cameras are not on the latest version.  I suggest that you update its firmware.  Kindly check these links below as reference guide:
What do I need to know about Arlo camera firmware updates?
How can I trigger my Arlo system to update its firmware?
Furthermore, about your concern on your 2 cameras that displays black & white, is there sufficient lighting on where they are deployed?
Let me know if you have already updated the firmware of your Arlo cameras and if same problem occurs.  I will be looking forward to your response.
Regards,
DaneA
Arlo Team
Kune
My arlo camera just is now streaming b&w, why is that?
Schorschi
Prodigy
Prodigy
It's dark?
the cameras sense the light level and automaticly switch over to B/W if light levels fall below a certain point
