2017-05-02 11:03 PM - edited 2017-05-03 12:45 AM
Dear Arlo customer,
On Tue 2nd of May, Arlo team is performing an emergency update to the cloud from 9PM to 9:15PM Pacific Time. Arlo users may not be able to log into the Arlo apps or the web portal during this 15 min update. But rest assured the cameras will continue to function as expected during this update and your recordings will be updated to the cloud as expected.
After the update is complete, you will be able to login and access all your camera activity as usual. We apologize for this inconvenience, and appreciate your patience and understanding.
UPDATE - May 2nd at 9:20 PM PDT
The update to the Arlo cloud has been completed with minimal down time. Users that may have attempted to log into the Arlo app or web portal during that time may have seen an error of "Incorrect Username or password". You should no longer encounter this issue now that the update is complete.
If you are still experiencing unexpected behavior with logging into Arlo please let us know at Arlo Support.
Thank You,
Arlo Team
Another user mentioned he was on with a tech...tech mentioned an issue on their end, they are working on it
I'm having the same exact issue, glad it's a problem on their end. I was about ready to return the thing. Just bought the 4 cam Pro system today. Not a great start...
Dear Arlo customer,
Thank You,
Arlo Team
