  • 10 Replies
  • 10754 Views
  • 4 Likes
  • 7 In Conversation
Sgcharles85
Im having troubles registering. Everytime i get to the terms and agreement page it says my session expired and to start all over. This is not a good start at all
UPDATE COMPLETED: Tue 2nd of May, Arlo team is performing an emergency update to the cloud
[ Edited ]
Dear Arlo customer,
On Tue 2nd of May, Arlo team is performing an emergency update to the cloud from 9PM to 9:15PM Pacific Time. Arlo users may not be able to log into the Arlo apps or the web portal during this 15 min update. But rest assured the cameras will continue to function as expected during this update and your recordings will be updated to the cloud as expected.
After the update is complete, you will be able to login and access all your camera activity as usual. We apologize for this inconvenience, and appreciate your patience and understanding.
UPDATE - May 2nd at 9:20 PM PDT
The update to the Arlo cloud has been completed with minimal down time. Users that may have attempted to log into the Arlo app or web portal during that time may have seen an error of "Incorrect Username or password". You should no longer encounter this issue now that the update is complete.
If you are still experiencing unexpected behavior with logging into Arlo please let us know at Arlo Support.
Thank You,
Arlo Team
10 REPLIES 10
MarsVoltron
I also am having the exact same issue. I know exactly how you feel.
JC73
Same problem... I was becoming crazy resetting my unit
MarsVoltron
Just read that they are having an outage causing the sign up issues. Hopefully they get it resolved soon.
Another user mentioned he was on with a tech...tech mentioned an issue on their end,  they are working on it
Dtnr8b
Did you ever get a fix for your problem?
MarsVoltron
I have not yet. Just waiting till they hopefully fix everything on their end. Apparently they're having issues causing the sign in issue
Dtnr8b
Thanks. Frustrating
deadringer
I'm having the same exact issue, glad it's a problem on their end. I was about ready to return the thing.  Just bought the 4 cam Pro system today. Not a great start...
Puffzotty
Have they resolve this issue yet? Ive been trying to register for hours and still no luck.
[ Edited ]
Dear Arlo customer,
Thank You,
Arlo Team
