  • 4 Replies
  • 937 Views
Rhartman
My Chime 2 stopped working after a power outage. I have gone through the reinstall process to where it asks for a local network (Arlo-***) . That network shows up on my phone but I do not have access to it and I don't know the password. Any suggestions?
@Rhartman wrote:
I only see the Arlo network requiring a password. I do not see any other unprotected network.
Did you try resetting the chime 2?
heck the phone's settings to see if unprotected WiFi networks are allowed to be connected to.
There is no password on the temporary network created by the chime 2 .  If you have an Arlo hub, then be careful to connect to the Chime network (not the hub's).  The hub network is secured, and you cannot join it.
As @jguerdat says, if you have an Android phone, then make sure the phone can connect to unsecured wifi networks.
Rhartman
