Can u adjust the brightness on the vmc3030
  • 7 Replies
  • 4103 Views
lildaddy75249
7 REPLIES 7
there is some iris control on the camera from the Live view screen... Start a live view and the icon that looks like a "sun" will give you a +/- iris setting.
lildaddy75249
I slide the iris no change in brightness for the vmc3030
It does respond but not super quick...maybe try another device to do it... it is only a +/- 1 or 2 setting btw
lildaddy75249
lildaddy75249 wrote:
https://arlo.netgear.com/hmsweb/users/library/share/link/ACC278484AB10008_201612
This is the brightest it gets
It seems like not the iris but the IR illuminators are not functioning... turn on a light in gargage and the picture should be better, showing the cameras ok.
Pull batteries and replace... armed the camera and go into a dark room/closet...looking at the front of cameras you should see the IR leds glowing slightly red ( 6 or so )
If not, make sure the IR is turned on in settings. The IRs should light up a garage well as alot bounches off the walls too.
Here's the Arlo IR's on outside...the small stump is 25-30 ft,  IR is center weighted
lildaddy75249
I did all the above still this is as bright as it gets
lildaddy75249,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
