Can u adjust the brightness on the vmc3030
there is some iris control on the camera from the Live view screen... Start a live view and the icon that looks like a "sun" will give you a +/- iris setting.
It does respond but not super quick...maybe try another device to do it... it is only a +/- 1 or 2 setting btw
This is the brightest it gets
lildaddy75249 wrote:
https://arlo.netgear.com/hmsweb/users/library/share/link/ACC278484AB10008_201612
It seems like not the iris but the IR illuminators are not functioning... turn on a light in gargage and the picture should be better, showing the cameras ok.
Pull batteries and replace... armed the camera and go into a dark room/closet...looking at the front of cameras you should see the IR leds glowing slightly red ( 6 or so )
If not, make sure the IR is turned on in settings. The IRs should light up a garage well as alot bounches off the walls too.
Here's the Arlo IR's on outside...the small stump is 25-30 ft, IR is center weighted
lildaddy75249,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
