I only have one camera. What can I do to get it working. This message was received on pc.
If logging out/in doesn't help as mentioned ... power down the base via the power button and restart it.
Did you try to log out and then back in ?
Powering down and re-starting solved it.
I had the same issue, powering off from the base worked for me!
Thanks!
