  • 4 Replies
  • 14404 Views
ptjohns10
I only have one camera.  What can I do to get it working.  This message was received on pc.
If logging out/in doesn't help as mentioned ... power down the base via the power button and restart it.
AnthonyArmato
Luminary
Luminary
Did you try to log out and then back in ?
ptjohns10
Powering down and re-starting solved it.
browneyes1127
I had the same issue, powering off from the base worked for me!
Thanks!
