With the latest app update I am able to create motion zones but I can't select/enable them.
Any ideas?
Also using Android mobile app V2.6.0-22600. I checked on the web version but it doesn't seem to have the zones options.
Thanks for your response
You are referring to Smart zones, right? Those are the only zones you can get with the original wireless cameras. I was just able to use a browser (Chrome) to create a zone with no issue. The zone is then applied automatically - no way to select use or not without deleting/creating the zone in Settings.
Im having an issues also. Its under Mode > Pencil of mode id like to edit > Pencil of camera id like to edit > Pencil next to "Detects Motion" > Motion Detection Zones.
Default is "Everwhere" selected, I can create a zone and name it, but cant change color or select the zone after creation. Zone "Everywhere" cant be unchecked.
Are we all talking about the original wireless cameras or the newer Pro ones? That would make a difference along with whether the camera has AC power.
Smart bzones are the ones provided by having a subscription that includes Arlo Smart. You can define a zone in Settings, My Devices, your camera, Video Settings on any Arlo camera, whether battery or AC powered. Regular motion detection zones require Pro 2 cameras on AC power or a Q camera.
I'm using the original Arlo. Not Arlo Pro... Not Arlo 2.
Also talking about "Motion Detecion Zones". I don't see anything referring to "Smart Zones".
If you look at the screenshot below, this is what I'm talking about. Like @Moser said .. Its under Mode > Pencil of mode id like to edit > Pencil of camera id like to edit > Pencil next to "Detects Motion" > Motion Detection Zones. I can create "Zone 1" which excludes some bushes/trees that always trigger my camera...but I can't enable Zone 1 or disable Everywhere.
Is there any Arlo documentation that states the Motion Detection Zones only work for Arlo Pro? Seems kind of odd that the feature is shown in my app... I can actually go as far as to create the zone by highlighting an area of the screen....but it won't let me enable?
If this is the case, then I am very disappointed in how they coded this application. When I see that a mobile app on my phone has updated to a new version via the Play Store and I go into it and see there's a new feature available, then I expect to be able to use that feature. If I can't use it because I haven't configured it yet or haven't subscribed to a service or whatever then there should be a message that appears indicating as such. Very disappointed!
Hey everyone,
Hi Jessica,
Thanks for passing this up to the dev team. Much appreciated, hope they are able to find a resolution!
Hi,
Just installed Arlo Pro system. Setup Activity Zones but unable to select those zones in the Motion Settings screen Its stuck on the 'everywhere' zone and I can change it. I have the Arlo Smart premier subscription and am running these on battery only. What do I need to do to activate the new motion detection zones?
Firmware: 1.092
Stuck on 'Everywhere' zone
AC power. Those zones are only active when external power is applied.
Looks like this still isnt fixed.
Just to be clear so that nobody tries to confuse this again, this is NOT the same as the Smart Zones or Arlo Smart. This is specifcally called "Motion Detection Zones" and is a setting that has very recently been added to the Arlo app for Arlo Wire Free.
I look forward to them getting this working because I'm grateful for this feature and was pleased when i noticed it today, but then quickly disappointed when it let me create the zones, but not turn them on 😞
With Arlo Smart, cameras no longer need to be plugged in to use activity zones.........
I don't have arlo smart so not sure why the OP can't get it to setup correctly, but it should work on battery power according to info from arlo website.
Cloud Activity Zones*
Use the handy Arlo App to customize your battery-powered camera’s view to detect motion—or ignore it—in the areas you choose. Now, you don’t need a plug-in camera to take advantage of one of Arlo’s most useful and popular features.
You're right - Smart works on battery-powered cameras. Without Smart, zones can only be implemented with power. I also realize now that this is a Pro camera, not a P2. Zones (not Smart) will only work on a P2 that's AC-powered since those cameras have both PIR and pixel detection capabilities needed for the use of zones.
I have a Pro 2 and this feature is not present all together. Really frustrating. I want to use one zone of the viewing area to trigger another camera in the system. I also want to record certain zones in certain modes, and not others. I hope this is resolved.
I also have a problem with the activity zones. The app is telling me I need to plug into electricity to have it work, although I already paid for a year to have Arlo do it with battery cameras. I have seven Arlo Pro 2 cameras, and they are ALL telling me this. Recently I bought three Arlo Pro, and they are working just fine, and I can set up activity zones. For me it seems to be Arlo Pro 2 vs Arlo Pro.
I had thought about buying a Pro2 to add to my existing setup (which I researched and found was supported) and wonder if the motion zones will be available to that camera?
