Notifications stopped working
Have 4 cameras and all are recording to the library. The notifications just stopped this week and I deleted app and reinstalled. I have an Android phone and it works fine. What would cause this? Notifications and recordings were all working together last week. My Model No. shows VMS3430-NAS100.
When you say "I have an Android phone and it works fine" is that the device that it now no longer works on?
I would start be restarting your base and also checking under modes to make sure that notifications are still set.
Also make sure that you did not set notifications off for Arlo on your phone.
Yes, the notifications are no longer coming through my phone and its set for notifications. Thanks I will reset the base. and see if that helps.
