I can log in to my account using an iPhone but not on the iMac. It was all working fine and nothign has changed. I had a link on my desktop. Now instead of logging in it just shows a bird with the WiFi symbol flashing - like the web site is down.
Are you using Safari? Try Google Chrome or Mozilla Firefox
I think it's because the Arlo site still uses Flash. Someone else said previously that they got their Safari to work by clearing the browser cache in Chrome??? Not sure if there's a workaround for you
got nothing
Have you rebooted the computer?
Contact Support at the bottom of the page and they can look at your account from their end
I am having this same problem. I can log in and look at cameras from iphone but beginning yesterday I cannot log in from my MAC. I just get the bird with wings moving.
Was there a solution to this problem??
Sunrisebeach,
If you were able to log in from your iOS device, this indicates an issue is potentially with the browser or computer. Consider trying from a different browser to see if you get the same behavior.
JameC
I switched from safari to firefox and was able to get the sign in page. I have been having a similar problem with WOOT.com, but not with Amazon, walmart, costco or Sams. After emailing back and forth with WOOT over the last week they finally said that they were having a problem with Safari.
"We’re sorry you were having problems placing order on safari. We were aware of the issue, and our site maintenance team is working on it. Its just that the safari has highly secure browser that blocks the pop-ups from Woot. Our team is working to fix that security issue."
Maybe Netgear is having the same problem
will
