unable to load plugin 'influxis', url: 'flowplayer/flowplayer.rtmp-3.2.13.swf'
Any ideas please? Get this when I try to watch Live on my PC
Which browser? Do you have Flash enabled? Don't ask me why it still needs Flash
I use Firefox.
It's alway worked.
It's also not alarming when you walk in front of it
That appears to be an issue with Flowplayer which isn't Adobe Flash. I don't know that Arlo supports that so you need to work with Flowplayer support. Reinstalling Flowplayer may help.
We need a lot more information about not working when you walk in front of the camera. Is it even armed? What mode are you using? Have you rebooted the base?
All recording again - I've not changed anything???!!!???
Live view looking for Flowplayer?
Strill not working on PC. Windows 7.
It used to use Abode, I think.
How do I tell Arlo to use Abode please?
Cheers,
Kev
My camera firmware is 1.3.314
I don't have 'Update' option in 'Device Info'
You may need to uninstall Flowplayer and install Flash from adobe.com.
I've done a system restore and everything back working.
Thanks for your help.
Cheers,
Kev
Having same issue. Only happpens while using FireFox. Does not with Edge. After you click on the camera again, it starts working. Windows 10, latest version.
Mines back working normally. Must have been a software update clash.
