Can't Add Camera To Smart Plan - Can't Add to Active Cameras
I have replaced the batteries on 2 of my arlos and in about a week, one has drained to 21% and the other has completely emptied.
Also, my front door Arlo hasn’t recorded or activated motion sensor since I got the Arlo smart subscription.
Please help as I’m losing my will it it.
Hi @T33KS
Have you made sure the camera is armed and has a rule set for motion? You can also try and reboot the base station/remove & re-add the cameras from Settings > My Devices
Is this occurring on the Arlo Mobile App or a web browser? Have you tried to assign it as an active camera on both platforms?
I have tried on the app and the website also with no luck.
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
Hi @T33KS
I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference:40785451
Hi,
Was this resolved somehow? I am having the same issue.
