Can't Add Camera To Smart Plan - Can't Add to Active Cameras
  • 9 Replies
  • 4043 Views
T33KS
I have replaced the batteries on 2 of my arlos and in about a week, one has drained to 21% and the other has completely emptied.
Also, my front door Arlo hasn’t recorded or activated motion sensor since I got the Arlo smart subscription.
Please help as I’m losing my will it it.
9 REPLIES 9
ShayneS
Hi @T33KS
Have you made sure the camera is armed and has a rule set for motion? You can also try and reboot the base station/remove & re-add the cameras from Settings > My Devices
T33KS
I have now done what you’ve suggested and the camera is recording again. But I have another trouble as I can’t reassign the camera onto Arlo Smart plan. I have already paid for the year but it wont let me put the camera back on. Any ideas?
ShayneS
Is this occurring on the Arlo Mobile App or a web browser? Have you tried to assign it as an active camera on both platforms?
T33KS
I have tried on the app and the website also with no luck.
ShayneS
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
ShayneS
Hi @T33KS
  I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference:40785451
T33KS
Brilliant thank you very much
Gowardo
Hi,
Was this resolved somehow? I am having the same issue.
ShayneS
Hi @Gowardo
Can you provide a little more detail regarding the issue you are experiencing?
