Can no longer access video in email after less than 48 hours
  • 7 Replies
  • 4702 Views
  • 2 Likes
kbridges
I just installed two cameras outdoors to catch someone stealing my mail from my mailbox which is accross the street.  Early morning on Feb.19th Arlo filmed a car stopping at the mailbox.  After less than 48 hours the video is no longer shared.  I thought the basic package storred the video in the cloud for seven days.  I have the video number.  Any way to get it back or is it still there?
Shared videos expire after 24 hours....
Go to your LIBRARY for the day and DOWNLOAD the file before it is gone... At day 8 from the event it is gone.
7 REPLIES 7
manfredz
Hero
Hero
learned something new.
did i get it right, the share is gone 2 after 2 days, but the vid is still there for the full 7 days?
btw, is there any way of seeing how close you are to your 1Gb limit other than estimating from the number of files x average size?
Yes... and if its important, get it now... the 7 days is a rolling date ...On day 8, day 1 is all gone.
You can fiq it out but not needed, Netgear hasn't enforce the 1 GB limit since they removed the usage gauge back in late 2015/ early 2016
BTW, 10 sec of video is just about 1mb...
manfredz
Hero
Hero
thanks.  keeping track of 7 days is easy. btw, i use 120 sec recordings and they're usually 7k.
kbridges
So how do you adjust the length of the vidio?
 go to Mode
Armed > to edit
Camera, Edit
Record Video >
Change the time on slider
Use the Back button on top left
Scroll all the way down to the bottom for SAVE
manfredz
Hero
Hero
yeah not exactly intuitive.  dont know if i read how in a forum post or stumled upon by going through setting.
then made one of those silly mistakes.  made a rule changing time to 120 sec for my cams but it didn't work.  took a bit to figure out the radio button was still on armed instead of the rule i created
