Delete modes from the scheduleI wa
I want to delete a schedule as I inadvertently set "Armed" to 24/7. If I add a new schedule, all I can see on the calendar is the old schedule with the entire calendar shaded. The only posts I can find on this topic seem to be from 2015 and refer to a different method of scheduling (drag and drop) than I have available with current software. How do I edit, or preferably, delete an old schedule?
You don't say what device your using, but on the PC you just reclick on the time slot already set and a window pops up with a delete button.
Must be done for each time slot previously set
