Can I use a WiFi extender port for my set up?
  • 1 Reply
  • 16468 Views
trustnohole
snip3rboy
Hi trustnohole,
I believe what you want to do is wire your base station to your WiFI extender, right?
That should be fine as long as your network configuration can do the following:
1. Allows the base station to get a dynamic IP address
2. Allows the base station to access the Internet
Hope this helps!
