Can I connect Arlo to a SmartThings Hub
  • 1 Reply
  • 2509 Views
rmw1101
Hello,
I am hopeing that you can help me.
I recently brought a Samsung Smart things hub, on which it says that it is compatible with the Arlo Wirefree..... this I was led to belive meant that the camera would connect to the SMT hub, and not need the Arlo hub also, as why say it is compatabile.
I am hoping that I am correct in thinking the camera will connect to the SMT i just dont know how.
Can anyone help?
Thank you all very much for your time, and help.
The compatibility is via software, not hardware. Any of the smart home methods require the same thing. The wireless cameras require the dedicated WiFi connection between the base and cameras. They won't connect to anything else.
