Cameras used to work, now rarely pick up movement
brandon_mc928,
Are you using a default mode (Armed) or a custom mode? It sounds like you may want to increase the sensitivity for your cameras within the rules.
I'm having the same problem. Cameras are about two years old, and always worked extremely well. I have them set to schedule at night, for one full minute of recording. I used to wake up to 10-20 recordings, everything from wild animals to cars driving down the street. About three weeks ago I noticed that I was only recording about 2-3 times a night. When I let the dogs out before bed, it always records me, but I'm two feet from the camera. Anything farther than that will not trip the motion sensors.
The cameras have not been moved (other than to change batteries), and the wifi is working fine. If I switch to live rather than schedule, there's no difference. Any chance the sensors have just gotten dirty with time and need maintenance? I'm stumped here.
I have a newer ArloQ inside the house, and that one is working perfectly. It's only the two outside.
Kathy
might be worth cleaning lens and sensors if simply that.
I'd also, bring them in , one by one, and walk in front back and forth at varying distances to see what is and isnt recorded.
Thanks so much. I'll give the cleaning a try. Are there instructions anywhere on how to do that? If not, I'll have my engineer hubby take a crack at it.
Well this is interesting. I just armed them, which I don't usually do during the day. Both cameras immediately tripped, three times in ten minutes from people walking down the street. Would a dirty sensor be less likely to work properly in the dark? Very odd that there's no issue with daylight, but barely working at night.
Seems that there would be less IR, especially reflected from the sun's output, so I'd think so.
Chapel,
Consider rebooting your base station using the on-off button. Allow the base station to come back online and try again. Do you still see the same behavior?
