I am having the same problem. The cameras come on like they are recording (red lights) and I get nothing!!! It just started today. Not sure what's going on.
A possible issue could be that you need to log out and back in - that's solved some issues for me in the past. If that doesn't work, reboot the base (use the power button rather than the restart button) and open and close the battery covers on the cameras. Maybe they're just weird and a reset will help. After all of this, does the issue remain? Can you verify that they're actually in use? Can you live view successfully? Is your schedule set properly (including rules and modes, verifying that checkmarks are green or black as appropriate)? What's happening with the running men - red or gray? Turn schedule off and set all motion on and off and check for proper operation.
Good luck...
