Only see base station under mode button. Cameras not present so cannot schedule them. In discussions other users had this problem, but seemed to resolve it with a reboot. This did not work for me. I have tried rebooting, restarting, resyncing cameras, but only failure. Anyone know what the issue is?
I talked to support and my understanding is that the cameras should not be listed under mode button, only the base station. Cameras are only listed under Settings button. I pointed out that the lastest documentation for the product was then incorrect. Support person replied that they would pass this information onto the appropriate channel. Below is partial transcript of converstation with Netgear support:
Click on the base station and go forth.
Sorry, tried that before, as it would seem like the obvious thing to do and it still does not work now. I've tried single tap, double tap, tap and hold. Only see base station listed. Wish it was that simple. Not sure if it related to the fact that I just have basic service? Currently have a ticket listed with Netgear support since first 90 days is free support. Hopefully they can provide a solution or answer to the issue.
Not related to the free plan - that's what I have, too. Have you tried both the app and multiple browsers? If one works, its not the setup, it's the app (try reinstall) or browser (sometimes flushing the cache helps). If all else fails, you probably will end up performing a factory reset using the reset button on the base until the LEDs flash amber. Remove all devices from Settings, My Devices. Add the base back in using the Add Device button in the Cameras tab and start fresh.
Tried from both my iPad Air iOS version 9.3.2 and from Safari version 9.1.1 on OS X version 10.11.5. Already tried reset once and then reboot once adding the base station and cameras back in. Still waiting for response from Netgear support.
Netgear support has requested that I log out of my account on my mobile device and then log back in. How many times I have done this I couldn't count. Their solution did not work. Sent reply and awaiting further instructions.
Yer 100% correct. There are a number of old articles and manuals that simply need to go away or be updated to the current methods and displays. The confusion is unnecessary and should have been handled long ago.
