If you removed the cameras from the system you will probably need to bring them close to the base to reconnect them. But, after that if you are simply changing batteries or re-syncing them you should be able to leave them where they are without bringing them down.
Brian
Welcome to the hell that is being an Arlo owner. I have to resync my cameras every few weeks. It sucks.
It’s too much hassle dealing with these cameras. I think it’s time to find something better.
it sounds like there may be some newer interference occurring. Did you happen to move the base station closer to any electronic devices or the router?
Negative, nothing has been moved or added in over 2 years except for my Ring doorbell that I added after my cameras were offline for over a week.
Have you tried to remove the cameras from the Settings > My Devices > Re-add and test again?
I have to remove and resync the cameras about every month to every 6 weeks. Not by choice......
