I just set my Arlo system up over the weekend and been testing it for a couple days. Both cameras don't seem to be sensing motion until right in front of the camera. I don't get notifications every time it does sense motion. One camera is live and recording in red color video. Let me know how to fix
Camera positioning is important - don't try to get a wide view. Rotate the cameras so only the actual area of interest is seen. Make sure motion is basically from side to side - PIR detectors don't work well when motion is directly at the camera. You can also change the motion sensitivity in your modes and rules - read the FAQs here on how to do this. Basically, go to the Mode tab, click on your base and edit your modes (Armed by default). Consider making your own custom modes for full control (another FAQ).
If you need, post screenshots of the camera views for suggestions.
The red tint is an artifact of the IR filter used for night vision. About all you can try is to open and close the battery door to see if the filter will unstick itself. A moderate jostling may also be useful. If not, it's a hardware problem and can only be solved by swapping at the store or use of the Contact Support link at the bottom here.
This might also do the trick: https://community.arlo.com/t5/Arlo/Red-tint/m-p/1299751#M36719
