- 2
I have all the settings correct with my 3 cameras ie motion is definitely set to on. motion is on with the green man etc. Cameras are picking up movement and sending notifications to my phone but when I log in to Arlo their is no footage to play? I have 3 Cameras pointing at different angles on the same post out the front of my house (could they be getting interference been so close to one another?). I have only been getting issues with this for about the last 7 days or so with detecting motion and notifying me but they are not recording. Sometimes I might get a recording off one camera were I should have 3 recordings from each cam. I am thinking I might need to do a power down the cameras and re-sync?
Any suggestions?
Thanks.
No user intervention was required by me at all... just started working this morning... all by itself.
Yes, a pain having to go through the process of disconnecting/reconnecting on the advice of Arlo (when it seems we didn't need to do this at all!), then re-positioning the cameras exactly where they had been before. Anyhow, mine are working now 🙂
You are right Warnzie. When I spoke to someone yesterday they told me they didn't have any other reports of such an issue so I told them to look at their own website's community forum for evidence that a widespread problem did potentially exist. I think we all expect these days for technology to have some issues from time to time but having good communication, so we don't think we're going stupid, by having a service update page where we can check first before we pull our systems apart thinking the problem exists with us locally.
Thanks for starting this thread Warnzie.
Everything seems to working properly now.
Out of curiosity did they tell you what the problem was?
Regards J
Hey guys,
I just want to share how I fixed the same issue I had for couple of weeks. It turned out that the issue was with DNS. I've been using google's DNS, but once I have changed it to use local one that is provided by ISP (TPG in my case), it's working just perfectly. I think netgear made changes in some host server locations and that is unknown from outside of Australia. It's worth to try with your ISP's DNS.
The Arlo development team has isolated the cause and has resolved this issue. A small number of Arlo users in the Asia-Pacific region (including Australia) were affected and we apologize for any inconvenience this has caused. We have taken steps to ensure that this problem does not occur again and added additional monitoring tools that will detect potential issues in the early stages so that user impact is minimized. Your patience in this process has been greatly appreciated.
Thank you!
I am having this issue today. Is there a problem with the cloud system?
The same thing just started happening again. Should I expect this to be a daily occurance? What good are my cameras if I don't get updates when I'm not home?
The Arlo team is aware that this issue is affecting some customers. Our engineering team is investigating the root cause and a fix will be released as soon as we have a resolution. Once a resolution is reached we will post an update. We appreciate your patience while we work to resolve this issue.
Thank you,
James,
Thanks for the reply. FYI I am experiencing this again today.
JamesC wrote:The Arlo team is aware that this issue is affecting some customers. Our engineering team is investigating the root cause and a fix will be released as soon as we have a resolution. Once a resolution is reached we will post an update. We appreciate your patience while we work to resolve this issue.
Thank you,
Really frustrating today. Tons of notifications, no recordings!! I had packages delivered, now tons of notifictions. Did someone steal them? I don't know! I may have to shut them off just to stay sane.
Wow. This thread began last year in September! It's now Feb. 2016 and this issue is affecting the customer base in the U.S. My issues aren't just with a long (2hr) delay in videos uploading and email notifications. And all the suggested "fixes" listed in multiple other threads aren't working. I have to reboot my system daily. Videos are recording up to 9 minutes and it's eating up the battery life. Videos sometimes never show up. There is a delay in recording so the motion that was detected has already occurred and the camera didn't catch any of it. A video of 3 minutes of nothing. All day today. It's 9 pm and I'm finally able to scroll through videos that were recorded at 5pm. What's going on and will it be fixed?
As you may have noticed, we are experiencing issues with our cloud servers which may be slowing down reception of alerts and video recordings. Our engineers are working on the situation with urgency and things should be back to normal shortly. In the meantime, we apologize for any downtime you’re experiencing and want to let you know that we are working non-stop to address the issue.
Update:
A fix for this issue has been released and has significantly improved Arlo performance. However, a side effect you may currently experience is the alert counter on the camera screen disabled and set to 0. Resolving this counter issue and further optimizing Arlo performance is our number one priority at this time and Arlo engineers are working non-stop to resolve this.
Please refer any additional comments on this issue to the following thread: https://community.netgear.com/t5/Motion-Detection/Email-Alerts-Video-Recordings-Not-Getting-or-Getti...
Thank you,
- 2
