Simple fix I hope...
The info that you HOLD the sync buttons for 2 secs is basically WRONG. I haven't seen a fix in the docs cause many system sit on store shelfs for a while.
SO, Do a quick push on the base sync button, then 1-2 secs later a quick push on the camera sync button... it should work fine.
As a PS.. it is possible the batteries were bad/old in the box...a couple other users complain of the same thing recently.
Also , when purchased on line ( battery junction ) the battereis run about $145 each
Nonnie wrote:
I tried your suggestion. I even took the batteries out of one of my cameras that is working and put the batteries from the camera I can't get to come on in it and the battery life is 90%. So I know the batteries are good. When I put the batteries in, it makes a clicking sound and a solid blue light comes on and then goes off.
The Clicking noise and Blue led flash when closing battery door is normal.
Do a power button reboot of the base, give it 2 mins about to come back online... when it does attempt the sync again as mentioned with a quick push of the sync butons.
