I bought the four camera system and one of my cameras won't sync. I've tried re-setting it by opening the battery compartment and closing it. A blue light comes on for a few seconds then goes off. I then attempt the sync process, but the camera never gives me a flashing blue light.
Just to be clear, you're only pushing the sync button on the base for 1-2 seconds, right?
You may need to use the factory reset on the base (hold the reset button until the LEDs flash amber) and start the process over again.
Mummolo,
You might consider trying a fresh set of batteries to see if you get the same behavior. Or try batteries from one of the cameras that is behaving correctly. Please let us know!
Dallas2,
What error message are you receiving? Are you able to live stream the camera or take manual recordings?
