Camera sensitivity
  • 6 Replies
  • 8872 Views
Llen
I want to adjust the camera sensitivity however I am unable to find the device once I go into the “mode” button as suggested in the instructions. All I get in mode is “security” and the options to arm or disarm. It does not list the devises at that point and there is no Capacity to edit. Can someone suggest what I need to do. I appreciate any assistance. Thanks
ChevyMama
Luminary
Luminary
@Llen I see, ok go into mode. What I see there is a list, armed, disarmed, schedule, geofencing, and custom. ( I have mine on custom mode) and at the very bottom is add a mode. I like mine on custom so I can customize the time for recording and sensitivity. I have mine set to when motion is detected, record video and I also have push notifications there too to email me. I hope this helps.
6 REPLIES 6
ChevyMama
Luminary
Luminary
@Llen go to mode, under where it shows "detects motion" there's a little pencil, click on that and that's where you can adjust your sensitivity. Hope that helps you.
Llen
Thanks for your reply, greatly appreciate your advice. However my problem is that when I go into mode I do not see anything other than the security icon and I only have options to arm or disarm. There is no “detects motion” nor a pencil icon. There is not list of devices or any other icons at all. I can’t seem to get past first base to try any adjustments. I assume that it is likely to be something simple that I am not doing correctly. Any ideas?....
Try power cycling the base as well as using both the app and a browser.
ChevyMama
Luminary
Luminary
Llen
That did the trick.
Thanks for your assistance. Well done
ChevyMama
Luminary
Luminary
@Llen Awesome! Glad I could help. Now if I could only get my camera to work!
