Are they visible in any scenario, web and/or app with any login? I assume you've been added as a friend. I don't know what would have happened but perhaps removing the friend account and re-adding would help.
Probably the best thing to do is create a trouble ticket. If someone posts here faster, so much the better but initiating a ticket improves problem tracking.
Good morning Beepr,
For good measure I would check the primary account and ensure all the cameras are marked as authorized for sharing.
- Log into the primary Arlo account
- Go to Settings
- Click on Friends
- Click the entry for your name/email address
- Ensure all cameras are showing a green check mark.
Note: If the camera is highlighted in grey that indicates the camera is not authorized for viewing for that friend/email address.
In the sample below you can see the "Back Yard" camera will not be viewable by this account/email however the Baby's Room camera is.
If this doesn't resolve the issue please contact our support center by visiting http://www.arlo.com/en-us/support/contact.aspx so they can investigate this issue further.
Best Regards,
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
I to have the same problem. Wife recieved invitation and can download app but can not get cameras up. Have check and rechecked cameras to be sent with invitation. Resent many times. She even deleted her account and reloaded. Same thing can not call up cameras but can see everything else.
r273,
After going through the steps above what is the status of the friend invite you sent out? If you go to Settings and then to Friends does it say "accepted" or "pending". If it says pending that means the invite was not properly accepted. When the invite is sent to the friend accounts e-mail you must click the "Create my own Arlo Account" link provided. This will redirect you to a login screen. At that login screen you must enter the friend account that you already have created. You might find it easier to do from a PC so you don't get the redirect link to download the application. The most important step is that you login from the page that the "Create my own Arlo Account" link takes you to as this is what triggers the invite to go from "pending" to "accepted".
Hope this helps!
