  • 2 Replies
  • 2845 Views
MBourez
I walk up to my car, I see the amber light start to blink, I get no notifaction that it recorded anything, and no video appears in the library
The box says model #VMS3130
Streak2
Master Master
Your batteries could be almost flat. Here is guide to what the flashing leds mean.
When you log into the app., what does it tell you about the battery voltage?
Is the camera still sync'd?
Replace the batteries and restart the base for good measure.
1.pngBlinks blue once. The camera is powered on.
2.pngSlowly blinks blue. The camera is syncing with the base station.
3.pngRapidly blinks blue. The camera is synced with the base station.
4.pngSlowly blinks amber. The camera’s batteries are low.
5.pngRapidly blinks amber. The camera did not sync with the base station.
6.pngBlinks amber and blue. A firmware update is in progress. DO NOT TURN OFF THE CAMERA.
Streak2
Master Master
steve_t
Master Master
Yep. Flat batteries. Open the app the check the battery level or really you can just change the batteries
