Battery lasting 1 day
Verify that the batteries are dead using a voltmeter. Fresh should read ~3.2v, dead ~2.75v.
What are the LEDs on the base showing over time? If the Camera LED show amber, there's a weak signal. Since you have various cameras doing this, the base could have a bad WiFi section or there's something near the base that's interfering with the signal.
Thank you for the reply. I have put the battery in the working camera and they are indeed dead, so they are being drained. The base is flashing green. I have made sure I have the current firware or update per the chat persons instructions. What else could it possibly be? Its getting expensive testing because of all the expensive batteries i have to buy lol.
jguerdat wrote:Verify that the batteries are dead using a voltmeter. Fresh should read ~3.2v, dead ~2.75v.
You must open a case for any hardware failure. These forums can only suggest possible solutions but can't get you a replacement.
