I have lost the charger to my Arlo Pro and when I try to charge it with my Arlo Baby Charger, it says to use a compatible charger. Will the Arlo Baby Charger not work to charge the Arlo Pro? Where can I buy just the charger and not pay $50 for a new battery and charger?
You can use any quality charger that supports Qualcomm QuickCharge, such as those for recent Samsung phones. The key is to use one that supports both 5v and 9v.
We have several mini usb chargers and tried them all and it kept giving us the same error that we needed to use a compatible arlo charger.
The specs are tight with the Arlo ... but the camera will run on a normal 5v usb adapter ( if enough current ) and you can pull the battery.... But as mentioned Qualcom dual v chargers do work...
I've tested a Samsung dual v charger ( for an S7 ) and it was fine
