Are you using OEM batteries?
What brand batteries? Rechargeable or not? What batteries worked fine originally? Having to wedge in a piece of plastic isn't normal.
Try power cycling the base as well as trying both the app and browser. Sometimes logging out and back in helps.
Sorry, not sure exactly what you're referring to. What steps have you tried? Fresh batteries? what are the symptoms - can you live view, etc.?
Angelarie3 wrote:
What I'm referring to is the customer who replaced the batteries & needed to wedge in apiece of plastic to make it work bc they said the batteries sounded loose. So do mine. They are brand new & the correct ones. I have no feed. Just a camera that says it needs new batteries on a green screen.
That USER you mentioned had purchase the wrong batteries... that's why they were loose.
the OEM type are CR123 batteries, lithium; one use ( not rechargeable )
sometimes labeled as CR123, CR123a, 123
see post;
2016-03-15 11:12 PM
I have replaced 4 new batteries but still not work. Screen say "It's time to change your batteries".
How can I fix this problem?
Thanks.
Go in to SETTINGS, pick the camera, and use REMOVE DEVICE
open and close battery door
bring camera back as new ( resync)
