Hi there. Since this morning my Arlo Basestation Firmware firmware 1.9.0.0_14639 has blinking lights. The internet light blinks steady green and sometimes flickering green. The camera light is blinking amber all the time. The system works fine. I have 3 Arlo H7 Firmware 1.2.11810 connected and 1 Arlo Q VMC3040r6 with Firmware 1.8.3.1_13001. I restarted the basestation but that doesn't help. The blinking is annoying like something is supposed to bring, especially the Amber light. Anyone with the same problem? Any suggestions? Thanks to advise. //Erwin
The Internet LED blinking is new behavior from a firmware update which indicates Internet access similar to how your router may do the same thing.
REwritten
Hi there. Since this morning my Arlo Basestation firmware 1.9.0.0_14639 has blinking lights. The internet light blinks steady green and sometimes flickering green. The camera light is blinking amber all the time. The system works fine. I have 3 Arlo H7 Firmware 1.2.11810 connected and 1 Arlo Q VMC3040r6 with Firmware 1.8.3.1_13001. I restarted the basestation but that doesn't help. The blinking is annoying like something is supposed to be wrong, especially the Amber light. Anyone with the same problem? Any suggestions? Thanks to advise. //Erwin
even here in Italy the same problems
Hi Paola
And suddenly the blinking is gone and basestation is back to normal.
Same for you?
it seemed right ..... now blinking..........
Ciao Paola,
non so se ti si è sistemato il problema ma a me continua a lampeggiare la seconda luce di verde e la terza di arancione....non so come sistemarla🙄....accetto consigli.
ciao
paolafa wrote:it seemed right ..... now blinking..........
Consider a system reset by removing all devices in Settings, My Devices. Use the Add Device button to add the base and sync the cameras. Verify that you have the latest firmware.
