I still want to get the text alert notifications, but is there a way to suppress the alarm? It's going off like a slot machine in vegas and driving me crazy!
on your phone if you go into the arlo app settings under notification tone you should have choice of "none". At least thats how it is on my android phone
Mode tab, select your base, edit your modes (Armed by default). All settings are in there. Be sure to save.
It only gives me a push notification on or off option. If I turn if off I won't get the push notification. If I leave it on, my phone sounds with each push. I want the notification without the sound.
Thank you that worked!
