I restarted it because one of the cameras would not connect. The base station shows a solid amber light. I reset my router and Arlo multiple times. Any more ideas why it won't connect? Thanks
It is finally connected to the internet but it won't recognize my phone?????
Now I am online but it is saying cameras need ilm update... I just bought them yesterday. Is this a true error message or just company?
Nothing to worry about.
Everytime internet goes out will I have to manually resync cameras? Like if we are away?
Other posts say this is a very infrequent problem (years ago) and maybe due to the Black Friday crush on their servers. Hopefully they will upgrade their back end to avoid this in the future.
All, Thank you I am Back up
Just bought my Arlo Pro 4-camera system for Black Friday and was excited to set it up last night. However, came to this message board because I was having connection issues from the base to my router. None of the resets suggested by users here worked. I was about to box it up and return to Best Buy today, but when I woke up, I got the steady green light vs. the dreaded amber all last night. No idea what happened, but I'll take it. Set up all 4 cameras and they are now monitoring the house.
Will wait and see if the signal keeps.
Make sure you guys do a complete motion test. Found out that these little P.O.S. cameras will not record until you get within 10'. Yes, set motion sensitivity to 100%. You can test the motion which works out to 25' (you will see the amber light blink) or so but will not record at that distance. Makes no sense. Going back to Sams Club tomorrow. I posted another post about this which basically says that point of motion detection is not the same as point of start to record.
I hope it works out for you but me personally, I need cameras “around” my house at various angles and heights. The 1 time in 2yr glitch doesn’t bother me.
Appreciate your concern though.
Tht1Guy: You are coming off like someone who is losing stock in the company. It doesn't take much to figure out how the system works with its limited features. I have been working with computers, software, data packets, blah blah blah for 30 years and have installed about 6 of these types of systems. Glad yours picked up raccoons at 15'. I am just letting everyone here know what I ran into. Motion detected during test at 20-25' but camera not recording until you get to about 5-10' of it. I did jumping jacks, raised my hands, and short of a seizure, moved a lot. Camera did nothing. I did another quality control check in my back yard which is a square formation. Set the cameras up and you can walk the farthest side of the perimeter starting at about 20' and walk all the way around and never get a video recording.
The camera is great for when the bad guy gets up to your house but for nothing else. This would probably work great for indoors but all of my cameras passed the motion test at 20-25' but failed to record at that distance.
RESOLVED: Some Arlo Base Station reporting as “Offline”
Following is an update on the Arlo Service interruption. On Friday November 24, 2017 at approximately 11:00am Pacific time, we experienced a major service disruption which impacted Customer’s ability to access their Arlo Systems. Services were restored at approximately 2:00am Pacific Time, Saturday November 25 although some Customers may have continued to experience issues for several hours after the fix was implemented. If you are still experiencing an issue with your Arlo system, please contact support at: 1-(408)-638-3750. We sincerely apologize for this service interruption and it certainly does not reflect our standards of service availability. Our technical teams continue to work diligently to ensure services remain available and we are reviewing our internal processes and systems in order to prevent this from happening in the future. Again, we apologize and thank you for your patience.
Just got the issue resolved.. Base station was working fine with my previous comcast router..But router failed and I had to replace it with comcast..When I connected the new router, the internet came on fine for all laptops /mobile phones etc.But the Arlo base stubbornly refused to connect... constantly the amber light was lit.
I did the factory reset at the back of the station but did not help..Then I connected the LAN cable to one of my Google wifi routers and it started working...My guess is some information gets cached, expecially if you have a previous connection working...Connecting to a completely new ethernet connection point should work...(if the factory reset doesn't do the trick). Hope this helps.
My base station would not connect to the internet. I checked everything, batteries in cameras, internet connection, reset the router, reset the base and nothing. I chatted with a tech from arlo and she said go to "mode" and disconnect the base. Then press the reset button on the back of the base for 30 seconds, then power off and on the base station. After add the base station under devices in your account. This worked for me, after it connects, you have to re sync the cameras.
Uggh, I'm into hour 20 of easy setup. My base station connects and disconnects all the time. So upon reading the above, if I hit the reset button, I'm suppose to hold it down the whole time along with the sync button until all the lights come on green? Or just hit the reset button and release? Why does mine connect sometimes then disconnects frequently?
Old information. Press and hold only the reset button until the LEDs flash amber. ALso remove all devices found in Settings, My Devices. Start fresh using the Add Device button in the Devices tab. Verify that all firmware is up to date by comparing what's found in Settings, My Devices, your cameras/base, Device Info to what's posted in the Release Notes section here.
The current reset procedure is to press only the reset button until the LEDs flash amber. We're told the old directions that include pressing the sync button is a known issue and will be removed.
1  -
1  -
1  -
