I restarted it because one of the cameras would not connect. The base station shows a solid amber light. I reset my router and Arlo multiple times. Any more ideas why it won't connect? Thanks
Thanks. All good now.
Interestingly, and I don't know how to feed this back, the instructions for synching the cameras make it harder than it actually was for me. The instruction is to hold the synch button down for a count of two seconds - didn't work. However, afetr much gnashing of teeth, I discovered that you need only touch the synch button, and the process started automatically.
I'm not sure whether this is just my machine, which seems unlikely given mass production, or if the software has improved. Either way, it's something Netgear could make more of...
Thanks again. Kudos given.
Just as a heads-up to everyone who can't get their base station to connect:
We also experienced a sudden inability for the base station to connect. I replaced the base station with a new one to no avail. Being in IT, I ran a few simple monitors and determined that Arlo does not just use HTTP/S. They also use NTP. Unfortunately, our ISP had decided to block NTP recently thereby bricking our Arlo base station. I validated this by trying our base station on a different service provider's line with the same router as well as VPN'ing to my work server with the same router and on the original line. In both cases the base station worked just fine.
I was able to get around this issue (sort of) since I have a Nighthawk router that has an older firmware version that supports Arlo. Although that router is unable to properly get time either, at least we can use our Arlo cameras (of course, the timestamps/rules we setup are useless since the router has an incorrect time on it).
Big time fail by Netgear using a protocol that more and more ISPs are blocking. They could have easily wrapped a call to get the current time in a webservice rather than relying on NTP.
If you want to find out if your ISP is blocking NTP, just run the Windows time command on a test server as follows:
C:\WINDOWS\system32>w32tm /stripchart /computer:us.pool.ntp.org /dataonly /samples:5
Failing output when connected to an ISP that blocks NTP:
Correct output when connected to an ISP that does not block NPT:
Please help. My system worked fine for a few months, but then after switching the isp router off and on, my netgear router has a solid amber power light! No other lights and the factory reset doesn't do anything! Reset and sync for 10seconds and still just the solid amber!
Changed internet provider can't get system back on line
Power off the modem, router and base. Start them back up in that order, waiting for each one to fully start before doing the next. Once back up, what are the base LEDs showing? Are you online?
You didn't reset since you used the old procedure. These days you use ONLY the reset button until the LEDs flash amber.
Bfrykberg,
Any router should work as long as the required ports are not blocked.
When you say the base will not connect to the internet, are you indicating that the internet LED never turns solid green?
And if that doesn't work, use the current method - same thing but ONLY the reset button.
I too had the same problem, with refurbished system I bought from Best Buy. Netgear techies couldn't get it , nor replacement they sent working so they sent another base station. This one worked fine. Great quality from the cams. Not ideal for everybody's needs but for me I'm glad I didn't give up (was tempted to several times). Hang in there.
i spent 2 weeks troubleshooting with netgear (mostly email) and telephone support before netgear concluded the base station was defect. Replacement worked out of the box. Opening ports, fixed IP, etc were all things we tried.
Hello.
I am facing the same problem. This unit worked great out of the box. I had no problems until batteries died. Now I am havng the same problem as everyone else in this thread. I have tried all the resets. Have you found a soluition to this problem? Frustrated. Please advise!
Thanks!
