  • 6 Replies
  • 2185 Views
Wilkins
Can’t get arlo to work or get online. Everything is plugged in. I did a reset and it still won’t work! These are the lights I have
6 REPLIES 6
atistailor
i have the exact same problem
Wilkins
I fixed it! Had to reset the router and added the station and camera like new
atistailor
did you reset your internet router or the smarthub? ive only tried resetting smarthub
Wilkins
No, I tried that and I had to restart the internet route
atistailor
oh ok thanks, unfortunately it didnt work for me.
Looks to me like @Wilkins posted a picture of his router, and not his base  - and the router was showing that it wasn't connected to the internet.
Your situation is likely different.  What is the status of your base station LEDs?  https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
Is this a new installation that has never worked, or is this a failure of an existing installation that used to work?
