Base unit is connected and working properly when using the phone app. Camera images can be seen and saved vids can also be seen. From the computer however, camreas cannot be seen and base station reports as offline. From the computer the saved images can be selected, viewed, and deleted.
Base and cameras have been restarted, resynced, and reset many times. Arlo, phone and computer use the same router/modem and there are no issues with connectivity. Using Chrome.
Have the same issue and also when logging in session times out. I am away so I cannot re-sync cameras. How to solve remotely?
One thing I have noticed is that the process of bringing up my system seems to be consistently very 'glitchy' - i.e., I often get the "base off line" message when trying to run the ap, and that simply waiting for 5 or 10 minutes, then re-attempting to open the portal is successful. It is either a hardware or software problem for me, I assume, but it is one that I have yet to satisfactorily resolve.
The Arlo team is currently investigating this issue. We appreciate your patience in this process and apologize for any inconvenience or frustration it may have caused. We have found that clearing your browser cache and logging back in will generally fix the issue. Also consider making sure you have the latest version of Adobe Flash Player installed and enabled. We have also found that the error can sometimes be the result of virus protection software. Again, we apologize for any frustration that has resulted from this and will continue to investigate the issue!
Thank you!
jt19,
The deactivate button removes the base station from the account. In order to add it back you must go to "Subscription" under settings and scroll to the bottom of the page and click "Add a base station". You must be connected to the same network as the base station in order to add it back to the account. Once it is back on the account you will have to sync each camera individually.
Hope this helps!
Also having same problems.
Chrome browser DOES NOT WORK.
Internet explorer and Microsoft Edge work most of the times but sometimes I do get the "base if offline" message.
Works flawlessly with IOS app and Android app.
This NOT a problem with routers or anything like that. It's an internal problem with Netgear.
I am having the same issue, however I am out of town and not at my house. Phone app works fine. When I go to arlo on my laptop, the cameras show the "play" arrow, but don't play.
The only way I have gotten it to work with Chrome is....
I have to log out of my Arlo account and then log back in
Thats the only thing that works on Chrome.
Spridell wrote:The only way I have gotten it to work with Chrome is....
Thanks, but still doesn't work for me. Any other suggestions?
seems Netgearhasa software issue
Have you tried any other browsers? Firefox would be a good one to try as long as Flash is installed.
Is this still working for you since you re-synced you cameras?
Hello, I am having the same issues, everything worked for about two weeks and now my computer keeps saying i am offline, but my app on my phone works fine.
I have powered down, reboted, uninstalled , reinstalled.
Thank you for your help.
Rebell4996
Rebell4996,
Some users have experienced issues due to security/virus protection software. Try disabling any you may have and attempt to log in. Be sure your Flash player is up to date and enabled. You might also consider trying to log in from a different browser to further isolate the issue.
- Has there been a concrete solution found for this? I am setting up my new system and the app on the I phone workds, but the pc shows everything as offline. I have reset, chnged browsers, looked at firewalls and nothing!
It's really hard setting things up on a phone and if this would work on the PC my life would be exponentially easier!
Does the app work properly on both WiFi and 3/4G? If not on WiFi, it may well be a router issue.
The app works fine connected to wifi or not.
is there a way to pinpoint if its a router issue? the base is plug into the router.
jguerdat wrote:Does the app work properly on both WiFi and 3/4G? If not on WiFi, it may well be a router issue.
If the app works on your home WiFi, its very likely not the router. If changing browsers doesn't fix it, it might be something in your computer's firewall and/or antivirus settings. It's been reported here before. You can try temporarily disabling them to see if that helps.
Firewall turned off. no change. left firewall off and then restarted everything. still nothing.
Any other suggestions??
What antivirus/spyware are you using? Also, you never explicitly said if using your home WiFi with your phone worked, just that WiFi worked.
Seems to be working now after clearing History, cache, cookies and hosted images app. Using Chrome and windows 10
Only worked once after clearing. App works on smart phone and remote computer and network. Running windows 10.
What happens if you log out and back in? Also, try a different browser multiple times?
I am using Chrome, tried IE. Have reset unit several times all with the same result. I have a feeling it is a software issue (possiblywith Windos 10) as when I log in from my home computer I have to hit the login button at least twice. Not so from remote computer and network, nor from my phone. I have sent support all the information. I have whitelisted the site in my anti virus and add blocker. no change.
It seems to be working with Firefox, But not Chrome or IE
