Just bought a 3 camera system. Two of the cameras sync and operate OK, but the third will sync but not capture a picture. When I click the LIVE button, the response is 'Request Timed Out'. How do I get a new camera? Thanks.
I was wrong. The camera will capture a picture and display it under 'Settings', but it will not display it under the 'Cameras'; it just shows a blank screen with 'Live'. When Live is clicked, I get 'Request timed out'.
Try resetting the camera by opening and closing the battery door. Also, use a different browser or the app.
Fatmax,
Also be sure your Adobe Flash player is on the latest version.
demetreb,
Consider removing the camera and going through the sync process again. I would recommend testing the camera before placing it back outside to make sure it is behaving properly.
Please let me know if you continue experiencing this issue.
